Received config request from the client (like fdb, identity manager, xnv, dot1ag, etc...) for the specified rule, of the given type (policy file or a dynamic rule), to get configured in the specified port and VLAN, relative to relName. This specified rule will be prepended or appended to the relative rule, as dictated by ruleAction. If the relative rule is not specified, the current rule will be prepended to the first or appended to the last configured rule on that port and or VLAN, depending upon the value of ruleAction. The ruleAction may have the action as prepend or append. If both the port and VLAN are not specified, then this rule will be applied as wildcard.
No action required - Informational message only.
Debug-Data
Receive request from client %appl% for configuring %ruleType% %ruleName% %ruleAction% %relName% in port %portNum% VLAN %vlanIfInst% direction %direction%
| Name | Type |
| appl | String |
| ruleType | String |
| ruleName | String |
| ruleAction | String |
| relName | String |
| portNum | SlotPort |
| vlanIfInst | uInt32 |
| direction | uInt32 |
